This sounds like it will be an awesome project! I think you should try to get data from the End-Use Load Profiles for the U.S. Building Stock project. Possibly the Virtual EPB project as well.
This sounds like it will be an awesome project! I think you should try to get data from the End-Use Load Profiles for the U.S. Building Stock project. Possibly the Virtual EPB project as well.project.
