A few points...
- There technically isn't a 90.1-2018, only 2016 and 2019.
- The OpenStudio _App_ 1.0 has the resources folder with OSMs to load as a library
- The OpenStudio _SDK_ 3.0 does not have a resources folder because it's a standalone product and not the GUI
A few suggestions...
- You can generate a 90.1-2016 baseline, which follows 90.1-2004, by removing the comment character (#) on line 27 of the
Create Baseline Buildingmeasure, i.e. thestandard_chs << 90.1-2004below.
# Define the arguments that the user will input.
def arguments(model)
args = OpenStudio::Measure::OSArgumentVector.new
# Make an argument for the standard
standard_chs = OpenStudio::StringVector.new
# standard_chs << '90.1-2004'
standard_chs << '90.1-2007 BETA'
# 1.13.1 onward supports 90.1-2010
if model.version > OpenStudio::VersionString.new('1.13.0')
standard_chs << '90.1-2010 BETA'
end
standard_chs << '90.1-2013'
# standard_chs << 'India ECBC 2007'
standard = OpenStudio::Measure::OSArgument.makeChoiceArgument('standard', standard_chs, true)
standard.setDisplayName('Standard')
standard.setDefaultValue('90.1-2013')
args << standard
You can use any of the available templates to generate a functioning model and then apply measures during run time to match 90.1-2016/2019 performance. These are the ones that come to mind...
- Set Exterior Wall Assembly to User Input U Value
- Set Exterior Roof Assembly to User Input U Value
- Replace Exterior Window Constructions with a Different Construction from the Model (required you to create a new construction first)
- Set Lighting Loads by LPD
A few points...
end
args << standard
A few points...
a standalone product and notno the GUI
end
args << standard
