The FloorSpaceJS, which is in the geometry tab of the OpenStudio application allows you draw over maps or imported plans images. So you are drawing 2d not 3D, but an extrude it to 3D. You could do something similar in the SketchUp plugin. Your question is pretty short, is this what you had in mind, or. We’re thinking about something else, like a perspective photo png being used to create 3D model? If that is the interest there are many different tools, including SketchUp that can use photogrammetry to create models from one or more images.
