Julien is right, it seems like the problem is your E+ path. Having gone through similar errors with GenOpt, I would also add that make sure that you have your variables marked in the template idf. This should not be a problem given that you are using the tutorial files.
One other common error I used to get with GenOpt was when the number of my algebraic calculations command file were more than a certain number. It seems as if GenOpt would terminate over a certain line of code in the command line and would not be able to complete all the addition/subtraction/multiplication etc. functions that I wanted.
