I think this is incorrect. E+ will assume you just have a large roof/ceiling surface and will calculate heat losses for the zone for that entire surface.
To do what you want, you need to add a shading surface group, and add surfaces in there: you can assign the same construction to those.
You can just add a Shading surface group, then go into your zone to select all your overhangs, cut them, go back to the shading surface group and do 'paste in place'.
To do what you want, so, you need to add a shading surface group, and add surfaces in there: you can assign the same construction to those.
there. You can just add a Shading surface group, then group. Then go into your zone to select all your overhangs, cut them, go back to the shading surface group and do 'paste paste in place'.place.
