Fixed after 3.0.1
Thanks for reporting this issue. It has been filed by @David Goldwasser at NREL/OpenStudio#4020 and fixed by NREL/OpenStudioPR#4030
The fix will be in the next release after 3.0.1.
Workaround
In the meantime, there is a workaround: do NOT drag the AvailabilityManagerNightCycle
from the hvac_library, instead use the dropdown "Use Night Cycle" and select "Cycle on..." option. This will ensure the class constructor is used instead of cloning, and the ModelObjectLists
will be properly populated.
Additional Notes
For the record, if you plan on using a "Control Type" that depends on these ModelObjectLists
, you probably should use the bindings to populate them carefully. If left blank, they will be defaulted to all zones served by the loop. You can follow the (quite extensive) logic implemented in ForwardTranslateAvailabilityManagerNightCycle.cpp#L128-L450
