That is exactly the intent of gbXML! If you write a gbXML file by hand that conforms to the schema you should be able to load it into most supporting tools (as long as they support the version of gbXML that you are authoring). There is a lot of good links if you scroll to the bottom of gbxml.org including a validator test suite that you can use to check that your export of a particular test case model is correct.
