See if this post on the annual end use summary report helps. Among other things it summaries air loops, plant loops, and zone equipment. This report pulls data from both the OSM model and the tabular EnergyPlus results. It is by no means a comprehensive report. You could extend existing tables or add new tables.
The first half of this YouTube video walks you through the report. Here is a link to the measure.
