If it is possible to set two setpoints in the primary loop then, by placing one at the chiller outlet and one at the ice storage outlet and also by employing the first law of thermodynamic for the mixing process after the tank, a relation between the mass flow rates of the bypass and mass flow rate of the tank can be obtained.
The only thing that I'm not sure is that if it's possible to place to setpoints at a single half loop.
