With reference of your simulation purpose, and guessing you are using energyplus, to reduce sim time you can:
1- select an appropriate Solar Distribution
algorithm in Building obj: leaving off "Reflections" increase speed time , as well to move from FullInterioAndExterior to FullExterior to MinimalShadowing. Generally FullExterior is a good compromise (at least as a starting point ) between acccuracy and sim time
2- use window multiplier rather than model each window with a fenestration obj
Blinds control on W/sqm hitting windows is compatible with the upspeeding solutions I stated. This could be different if you need a detailed interior solar distribution : e.g.
-to have daylighting illuminance maps, or
-for artificial lights dimming based on daylight illuminance level, or
-to model indirect solar daylight from a zone to an inner one through an internal window,
-etc
Blinds control on W/sqm hitting windows is compatible with the allows upspeeding solutions I stated.
-etc
2- use window multiplier rather than model each window wondow with a fenestration obj
Blinds control on W/sqm hitting windows allows upspeeding solutions I stated. This could be different if you need a detailed interior solar distribution : e.g.
-etc
2- use window multiplier rather than model each wondow with a fenestration obj
-etc
