Why not use a cooling tower to do the cooling in this case? EnergyPlus allows plant loops of type "cooling","heating", or "condenser". In your loop now you're doing both heating and cooling at the same time on the same loop. When you use a cooling tower you would not need the chiller loop anymore.
