Sorry, this content is no longer available
Thank you so much for your answer. I have to model an existing building with outdoor shading blinds, in this way, If I correctly understood the switchable glazing shading type, it directly works on the glazing transmittance, setting it according to daylight level using meetdaylightilluminance, and with this it would not switch clear/total dark only, but also average position. Am I right? But I would lose the reflection contribution of external blinds in this way, while it should be consider by using blind shading type, right?
