Hi,
I'm not an advanced user, but I think you should run idf file and look for the errors (exporting models from Designbuilder can take a lot of errors when running on EnergyPlus). If everything is good, then you should have in idf editor the output meters you are looking for. Just add it and run it again.
In addition, take a look on Input Output Reference to see what are the outputs meters for your HVAC system.
I hope it helps you.
Regards, Rui Oliveira
