EPW MAP (https://www.ladybug.tools/epwmap/) is great but not quite up to date with all the http://climate.onebuilding.org files that are out there. If you go to climate.onebuilding.org, each of the WMO regions have a kml file that will show you to the available files as well as enable you to download.
Dr Yi Zhang also has a site: https://app.ensims.com/epwmap.html
Linda
