To compile EnergyPlus see the GitHub page for the development project:
https://github.com/NREL/EnergyPlus
At the bottom is a link to how to build EnergyPlus:
https://github.com/NREL/EnergyPlus/wiki/BuildingEnergyPlus
I would suggest that you make sure you can build EnergyPlus without any modifications before adding the module that you have developed.
You should probably also look at the rest of the wiki related to the project since it contains development information:
You are a very adventurous new user! Good luck.
