The Bad Allocation error will happen when your computer is out of memory. That is why the file runs when you reduce the size of the map. How much memory does your computer have? You could try using a different computer or try reducing any unnecessary output reporting (Output:Variable) or combine zones if possible. Anything to reduce the size of memory needed to run the simulation.
