If you look at the answer to this earlier question that is about using standards to add space types you can see that the Space Type and Construction Set Wizard measure also adds construction sets using standards. Below is the link to the line that calls the model_add_construction_set method. https://github.com/NREL/openstudio-extension-gem/blob/develop/lib/openstudio/extension/core/os_lib_model_generation.rb#L3172
