The facility tab with your building selected exposes the building orientation.
If you are doing a parametric study, we also have a measure that rotates building relative to current orientation.
A note about building rotation. Space and building shading surfaces will rotate with the building, site shading will not. Just something to keep in mind of you are using site shading. Even if this is the behavior you want, the origin of the model for the rotation will become important.
