The Parametric Analysis Tool isn't intended to run a single simulation. Try adding one or more measure to your workflow with at least one measure argument used as a variable. Make sure your project has two or more design alternatives before you try to run it.
The Parametric Analysis Tool isn't intended to run a single simulation. Try adding one or more measure to your workflow with at least one measure argument used as a variable. Make sure your project has should have two or more design alternatives before you try to run it.it.
