UPDATE: We have addressed the account login issues on our website. If you have had issue but have not gotten an email from us, please try again to request a password reset, or to create a new account if you do not have one yet. It should be working now. Thanks,
We will address this account issues you are having but beyond that I just wanted to share alternate public download locations from the release section of the GitHub repositories. You will need to scroll down to the assets section after the release notes. Then pick the installer matching your platform. Don'd choose the source code options.
The OpenStudio CLI can be downloaded from
https://github.com/NREL/OpenStudio/releases
The OpenStudio Application can be downloaded from
https://github.com/NREL/OpenStudioApplication/releases
PAT can be downloaded from
https://github.com/NREL/OpenStudio-PAT/releases
and the SketchUp Plugin can be downloaded from
https://github.com/NREL/openstudio-sketchup-plugin/releases
Note that The OpenStudio Application and PAT already contain the OpenStudio SDK, so unless you intend to use the OpenStudio SDK on its own you don't need to download that. Additionally to use the OpenStudio SketchUp Plugin, in addition to needed SketchUp, you also need to have the OpenStudio Application.
In the future if anyone has issues logging into https://www.openstudio.net/ please email OpenStudio@nrel.gov and in the body of the message list the email you used to register and your user name.
We will address this account issues you are having but beyond that I just wanted to share alternate public download locations from the release section of the GitHub repositories. You will need to scroll down to the assets section after the release notes. Then pick the installer matching your platform. Don'd choose the source code options. repositories.
