Are you doing some little modifications to your IDF through IDF Editor before running it through EP Lunch? if so, check "File" > "Save Options" >"Original with New at bottom" to keep your preferred order
Are you doing some little modifications to your IDF through IDF Editor before running it through EP Lunch? running? if so, check "File" > "Save Options" >"Original with New at bottom" to keep your preferred order
order image description
