If you make a new EnergyPlus measure it will come with a basic functional test that generates an IDF from an OSM on the fly using the code you are referring to. Here is an example of this forward translation in one of our tariff measures.
As a note, if you are already creating an OpenStudio Workflow (OSW) and running that via the OpenStudio CLI, it will handle the forward translation for you. You can pass it a --measures_only argument to not run the simulation in EnergyPlus if you plan to run it elsewhere.
