You should connect your space(s) to the thermal zone (s). Select the 'Spaces' tab, go to 'My Model', open the 'Thermal Zones', and drag & drop the 'cube béton' thermal zone under the 'Thermal Zone' column. I could run the simulation successfully. Also, your hot water loop is not connected to anything else. You should remove that loop as well.
You should connect your space(s) to the thermal zone (s). Select the 'Spaces' tab, go to 'My Model', open the 'Thermal Zones', and drag & drop the 'cube béton' thermal zone under the 'Thermal Zone' column. I could run the simulation successfully. Also, your hot water loop is not connected to anything else. You should remove that loop as well.successfully.
