Work efficiency 0.7 is not reasonable.
Usually it shlud be 0 or around it. It rapresent the mechanical work done by people, e.g. the difference in height going up the stairs that in a minimum part of the metabolic rate.
Plase see calc below (from Fanger equations), as example:
Work efficiency 0.7 is not reasonable.reasonable.
Plase see calc below (from Fanger equations), as example:example
Usually it shlud be 0 or around it. It rapresent the mechanical work done by people, e.g. the difference in height going up the stairs that in a minimum part of the metabolic rate.rate
