In the OS App, priority is based on the order the equipment is added to the zone or the order from top to bottom. So, to change priority, users unfortunately have to delete objects and reorder them.
Here's some Ruby code I've used to do that using the SDK. This will swap the first and second zone equipment order.
model.getZoneHVACEquipmentLists.each do |obj|
  clg_eqpt = obj.equipmentInCoolingOrder
  htg_eqpt = obj.equipmentInHeatingOrder
  obj.setCoolingPriority(clg_eqpt[0], 2)
  obj.setCoolingPriority(clg_eqpt[1], 1)
  obj.setHeatingPriority(htg_eqpt[0], 2)
  obj.setHeatingPriority(htg_eqpt[1], 1)
end
Here's some Ruby code I've used to do that using the SDK. This will swap the first and second zone equipment order.SDK.
end
model.getZoneHVACEquipmentLists.each do |obj| |obj|
clg_eqpt = obj.equipmentInCoolingOrder htg_eqpt = obj.equipmentInHeatingOrder obj.equipmentInHeatingOrder
obj.setCoolingPriority(clg_eqpt[0], 2) obj.setCoolingPriority(clg_eqpt[1], 1) 1)
obj.setHeatingPriority(htg_eqpt[0], 2) obj.setHeatingPriority(htg_eqpt[1], 1)
end
