EnergyPlus 9.2 will work with the BCVTB 1.6.0 if you set it up to use EnergyPlus 9.2. This can be done by setting the variable ENERGYPLUS_BIN which is in the systemVariables-windows.properties (windows) to the path to EneryPlus 9.2. systemVariables-windows.properties is located in the bin folder of your BCVTB installation. Depending on your operating system, use the correct file. Please note that to run the example files which come along with the BCVTB 1.6.0 that you will have to transition them to version 9.2.
