That is an odd error, we will look into it. In the meantime, can you see if running scan for tools solves your issue?
Update
The issue is that the 'calibration_reports_copy' measure does not have a 'measure.rb' file in the directory. It seems like this measure was created, added to the workflow, then the measure.rb file was removed. The measure.rb file is the actual code to execute the measure so this is a valid error. However, the apps should catch this without crashing. To fix this right now, remove the 'Calibration Reports Copy' measure from your workflow. You might as well delete it from disk too so you don't get burned by this again.
Update
