Hello, in the documentation for Buildings.Fluid.Sensors.TemperatureTwoPort, I read
Setting transferHeat = true is useful, for example, if the sensor is used to measure the fluid temperature in a system with on/off control on the mass flow rate. If transferHeat were false, then the sensor output T would remain constant if the mass flow rate is set to zero, and hence the controller may never switch the mass flow rate on again.
Maybe this relates to your issue here?
