I was able to solve this. The key was using the as the sensor Object IDF name. This caused DesignBuilder to look up the occupancy schedule for each zone. My final working code is below, which randomizes both the occupancy and the internal equipment power level.
<ForAllOccupiedZones>
   Schedule_Value_Occ_<LoopZoneVariableName>,
   <LoopZoneAttribute OccupancySchedule>,
   Schedule Value;
Output:Variable, <LoopZoneAttribute OccupancySchedule>, Schedule Value, Hourly;
Output:Variable, <LoopZoneAttribute OccupancySchedule>, Schedule Value, Daily;
<LoopNextZone>
   Schedule_Value_Eq_<LoopZoneVariableName>,
   <LoopZoneAttribute EquipmentSchedule>,
   Schedule Value;
<LoopNextZone>
EnergyManagementSystem:Actuator,
   Number_of_People_<LoopZoneVariableName>,
   PEOPLE <LoopZoneIDFName>,
   People,
   Number of People;
<LoopNextZone>
   Power_Level_<LoopZoneVariableName>,
   <LoopZoneIDFName> EQUIPMENT GAIN 1,
   OtherEquipment,
   Power Level;
<LoopNextZone>
EnergyManagementSystem:InternalVariable,
   People_Count_Design_Level_<LoopZoneVariableName>,
   People Count Design Level;
Output:Variable, PEOPLE <LoopZoneIDFName>, People Count Design Level, Hourly;
<LoopNextZone>
   Other_Equipment_Design_Level_<LoopZoneVariableName>,
   <LoopZoneIDFName> Equipment gain 1,
   Other Equipment Design Level;
<LoopNextZone>
   People_Occupant_Count_<LoopZoneVariableName>,
   People Occupant Count;
Output:Variable, PEOPLE <LoopZoneIDFName>, People Occupant Count, Hourly;
<LoopNextZone>
   Occupancy Factor,
   AfterPredictorBeforeHVACManagers,
   OccFactor;
   OccFactor,
   SET fac = @RandomNormal 1 0.2 0.5 1.5, ! Mean SD LowerLimit UpperLimit
   SET Number_of_People_<LoopZoneVariableName> = fac*Schedule_Value_Occ_<LoopZoneVariableName>*People_Count_Design_Level_<LoopZoneVariableName>,
   SET fac2 = @RandomNormal 1 0.2 0.5 1.5, ! Mean SD LowerLimit UpperLimit
   SET Power_Level_<LoopZoneVariableName> = fac2*Schedule_Value_Eq_<LoopZoneVariableName>*Other_Equipment_Design_Level_<LoopZoneVariableName>,
<LoopNextZone>
   ! add program code
   Schedule Value;
<LoopNextZone>
   Schedule Value;
<LoopNextZone>
   People,
   Number of People;
<LoopNextZone>
   OtherEquipment,
   Power Level;
<LoopNextZone>
<LoopNextZone>
<LoopNextZone>
<LoopNextZone>
   Occupancy Factor,
   OccFactor;
   OccFactor,
<LoopNextZone>
   ! add program code
EnergyManagementSystem:Sensor, Schedule_Value_Occ_<LoopZoneVariableName>, <LoopZoneAttribute OccupancySchedule>, Schedule_Value_Occ_, , Schedule Value; Output:Variable, <LoopZoneAttribute OccupancySchedule>, , Schedule Value, Hourly; Output:Variable, <LoopZoneAttribute OccupancySchedule>, , Schedule Value, Daily; <LoopNextZone> <ForAllOccupiedZones>
EnergyManagementSystem:Sensor, Schedule_Value_Eq_<LoopZoneVariableName>, <LoopZoneAttribute EquipmentSchedule>, Schedule_Value_Eq_, , Schedule Value; <LoopNextZone> <ForAllOccupiedZones>
EnergyManagementSystem:Actuator, Number_of_People_<LoopZoneVariableName>, PEOPLE <LoopZoneIDFName>, Number_of_People_, PEOPLE , People, Number of People; <LoopNextZone> <ForAllOccupiedZones>
EnergyManagementSystem:Actuator, Power_Level_<LoopZoneVariableName>, <LoopZoneIDFName> Power_Level_, EQUIPMENT GAIN 1, OtherEquipment, Power Level; <LoopNextZone> <ForAllOccupiedZones>
EnergyManagementSystem:InternalVariable, People_Count_Design_Level_<LoopZoneVariableName>, PEOPLE <LoopZoneIDFName>, People_Count_Design_Level_, PEOPLE , People Count Design Level; Output:Variable, PEOPLE <LoopZoneIDFName>, , People Count Design Level, Hourly; <LoopNextZone> <ForAllOccupiedZones>
EnergyManagementSystem:InternalVariable, Other_Equipment_Design_Level_<LoopZoneVariableName>, <LoopZoneIDFName> Other_Equipment_Design_Level_, Equipment gain 1, Other Equipment Design Level; <LoopNextZone> <ForAllOccupiedZones>
EnergyManagementSystem:Sensor, People_Occupant_Count_<LoopZoneVariableName>, PEOPLE <LoopZoneIDFName>, People_Occupant_Count_, PEOPLE , People Occupant Count; Output:Variable, PEOPLE <LoopZoneIDFName>, , People Occupant Count, Hourly; <LoopNextZone>
EnergyManagementSystem:ProgramCallingManager, Occupancy Factor, AfterPredictorBeforeHVACManagers, OccFactor; OccFactor;
EnergyManagementSystem:Program, OccFactor, <ForAllOccupiedZones> SET fac = @RandomNormal 1 0.2 0.5 1.5, ! Mean SD LowerLimit UpperLimit SET Number_of_People_<LoopZoneVariableName> Number_of_People_ = fac*Schedule_Value_Occ_<LoopZoneVariableName>*People_Count_Design_Level_<LoopZoneVariableName>, facSchedule_Value_Occ_People_Count_Design_Level_, SET fac2 = @RandomNormal 1 0.2 0.5 1.5, ! Mean SD LowerLimit UpperLimit SET Power_Level_<LoopZoneVariableName> Power_Level_ = fac2*Schedule_Value_Eq_<LoopZoneVariableName>*Other_Equipment_Design_Level_<LoopZoneVariableName>, <LoopNextZone> fac2Schedule_Value_Eq_Other_Equipment_Design_Level_,
! add program code ;
