After running the FMU, a folder will be created which is called Output_EPExport_XXX. XXX will be your FMU model instance name. In that folder, you can see the IDF which is used for the run as well as the RunPeriod. You can also look at the output results file of the EnergyPlus FMU (e.g. .csv file) to see the simulation period.
