What did you do after you selected those variables from the rdd file? Paste them into your input file (idf)? And then correct the syntax? The part of the error that says "Hourly" is not a valid Object Type usually indicates that there is not a comma before the word "Hourly". And there needs to be a semi-colon at the end of each line.
Output:Variable,*, Zone Ideal Loads with Total Heating Energy, Hourly;
