If the Equipment object (e.g., ElectricEquipment) is located in a conditioned zone, you can set its Fraction Lost field to 1.0. This will mean that none of the internal gains are seen by the HVAC system.
Alternatively, you could model the laundry room as a separate thermal zone that is not conditioned.
