I am not familiar with FMPy but based on what I am seeing, I suggest to use the primitive functions setReal(), getReal(), doStep (similar to what is done https://github.com/CATIA-Systems/FMPy/blob/master/fmpy/examples/custom_input.py) so you can set time-dependent inputs.
Please note that that example is for FMI 2.0 so you need to adapt it and call the corresponding FMI 1.0 functions.
Currently, it seems like you are only setting the initial value of yShade but EnergyPlus FMU will be updated based on the input values set during the time stepping.
If the simulate_fmu() function you have used in your example accepts a time-dependent input object, it may be easier to control your input that way.
P.S. Looking at https://github.com/CATIA-Systems/FMPy/blob/master/fmpy/examples/coupled_clutches.py it seems like the simulate_fmu() does accept an input object, see line 33 of that example. You may be able to change your input that way as well. Best will be to read the documentation of fmpy to see how to set-up such object.
Currently, it seems like you are only setting the initial value of yShade but EnergyPlus FMU will be updated based on the input values value set during the time stepping.
If the simulate_fmu() function you have used in your example accepts accept a time-dependent input object, it may be easier to control your input that way.
