If everything @MatthewSteen has suggested fails, open up the .osm in your favorite text editor such as Notepad++, search for the surface by it's name "4B8349", and delete it. Hopefully you don't have hundreds of them.
You should see something like this:
OS:SubSurface,
  {48fbbea4-8111-4558-94d1-e4a0bb66ea18}, !- Handle
  4B8349,                                 !- Name
  FixedWindow,                            !- Sub Surface Type
  ,                                       !- Construction Name
  ,                                       !- Surface Name
  ,                                       !- Outside Boundary Condition Object
  ,                                       !- View Factor to Ground
  ,                                       !- Shading Control Name
  ,                                       !- Frame and Divider Name
  ,                                       !- Multiplier
  ,                                       !- Number of Vertices
  250.97, 337.66, 8.49,                   !- X,Y,Z Vertex 1 {m}
  250.97, 337.66, 6.40,                   !- X,Y,Z Vertex 2 {m}
  245.60, 328.83, 6.40,                   !- X,Y,Z Vertex 3 {m}
  245.60, 328.83, 8.49;                   !- X,Y,Z Vertex 4 {m}
Normally, the "Surface Name" attribute should have a handle, something like {425aa235-877f-45fc-a7ca-00da4fb1e22d}, but for you it'll be blank.
Make sure you delete everything.
Notice the last attribute X,Y,Z Vertex 4 {m} ends with a ;, not a ,. That's the delimiter for objects in both OpenStudio and E+.
OS:SubSurface,
  4B8349,                                 !- Name
  ,                                       !- Surface Name
  ,                                       !- Multiplier
Notice the last attribute X,Y,Z (X,Y,Z Vertex 4 {m} {m}) ends with a ;, not a ,. That's the delimiter delimeter for objects in both OpenStudio and E+. E+.
If everything @MatthewSteen @MattewSteen has suggested fails, open up the .osm in your favorite text editor such as Notepad++, search for the surface by it's name "4B8349", and delete it. Hopefully you don't have hundreds of them.
OS:SubSurface,
  4B8349,                       9758f4c7141c4eacbf0f_glz_0_0,           !- Name
  ,                                       !- Surface Name
  ,                                       !- Multiplier
Notice the last attribute (X,Y,Z Vertex 4 {m}) ends with a ;, not a ,. That's the delimeter for objects in both OpenStudio and E+.
