I just added an updated Annual End Use Breakdown measure to BCL. it includes air and plant loop summaries. As shown below it does link the chiller loop to condenser loop.
The code below is within a loop of all supply side components for the chiller loop. Once a ChillerElectricEIR is found then component.secondaryPlantLoop returns an optional.
elsif component.to_ChillerElectricEIR.is_initialized
component = component.to_ChillerElectricEIR.get
sizing_source_units = "W"
sizing_target_units = "Btu/h"
if component.referenceCapacity.is_initialized
sizing_ip = OpenStudio.convert(component.referenceCapacity.get,sizing_source_units,sizing_target_units).get
sizing_ip_neat = OpenStudio.toNeatString(sizing_ip,2,true)
else
sizing_ip_neat = "Autosized"
end
value = component.referenceCOP
value_neat = OpenStudio.toNeatString(value,2,true)
description = "Reference COP"
@output_data_plant_loops[:data] << [component.iddObject.name,sizing_ip_neat,sizing_target_units,description,value_neat,"",""]
# second line to indicate if water or air cooled
if component.secondaryPlantLoop.is_initialized
@output_data_plant_loops[:data] << ["#{component.iddObject.name} (cont)","","","Chiller Source",component.secondaryPlantLoop.get.name,"",""]
else
@output_data_plant_loops[:data] << ["#{component.iddObject.name} (cont)","","","Chiller Source","Air Cooled","",""]
end
The code for this is in the os_lib_reporting.rb file in the resources folder of the measure.
I just added an updated Annual End Use Breakdown measure to BCL. it includes air and an plant loop summaries. As shown below it does link the chiller loop to condenser plant loop.
else
end
else
end
I just added an updated Annual End Use Breakdown measure to BCL. it includes air an plant loop summaries. As shown below it does link the chiller loop to plant loop.
else
end
else
end
The code for this is in the os_lib_reporting.rb file in the resources folder of the measure.os_lib_reporting.rb
