EnergyPlus material object 'Material 1' in your model has an unrealistic specific heat value (0.1 J/kg-K) that is below the allowable minimum value of 100 J/kg-K. This is likely because you created a default material in OpenStudio with specific heat of 0.1 J/kg-K and did not adjust the value to match your target material. If this material is not used in an construction in your model, delete it, otherwise update the material properties to have realistic values matching your target material. In OpenStudio, you can drag and drop materials from the library into your project.
