In addition to some of the recommendations below, the solution to this is by:
- Before anything, ensure that your AWS account has allowable vCPUs > 36 cores to take full potential of PAT's available AMIs. You can easily request an increase from AWS and you'll get a response within 2 hours.
- Setting up a completely new PAT project (don't copy PAT folders or save-as)
- Entering AWS cluster settings.
- Attempting to connect to AWS. You will notice that this attempt will fail, it's okay.
- Save PAT (never force close), close after saving, and then reopen your PAT project
- Attempt a connection again to AWS; this will highly likely to succeed.
In addition to some of the recommendations below, above, the solution to this is by:
In addition to some of the recommendations above, below, the solution to this is by:
