I'm having the same problem. I've been using BEopt since v.2.2 and have not had this happen before. I've tried restarting my computer. Also tried removing and re-installing BE2.8. I had updated to 2.6, 2.7 and 2.8 sequentially. I tried manually clearing the files in the TEMP1 folder. I had not opened any of those files. I've tried to find how to disable the firewall for BEopt but I'm not good at "under the hood" work when it comes to computers.
One clue is that just before this error started appearing, I ran a simulation with multiple cases, as I've done many times before. This time, only the first case had information in the output file--all of the other cases had run but showed nothing in the Output page.
