I'm not familiar with the .setDescription function and typically use the following for double arguments:
Arguments Method
fan_rise = OpenStudio::Ruleset::OSArgument::makeDoubleArgument("fan_rise", true)
fan_rise.setDisplayName("Pressure Rise {inH2O}")
fan_rise.setDefaultValue(-1)
args << fan_rise
This is from a measure I wrote to Set Fan Inputs which allows the user to select a fan type and change any or all of the inputs. I use a negative default value as a flag to check whether the user wants to change a field. Not the most elegant solution but it works.
Run Method
fans.each do |fan|
if fan.name.to_s.include? string or string == "*.*"
# set common inputs
if fan_eff_tot > 0
fan.setFanEfficiency(fan_eff_tot)
end
if fan_rise > 0
fan.setPressureRise(fan_rise_si)
end
Arguments Method
args << fan_rise
fan_rise This is from a measure I wrote to Set Fan Inputs which allows the user to select a fan type and change any or all of the inputs. I use a negative default value as a flag to check whether the user wants to change a field. Not the most elegant solution but it works.
Run Method fans.each do |fan|
fans.each do |fan|
# set common inputs
if fan_eff_tot > 0
end
if fan_rise > 0
end
Arguments Method
Run Method
fans.each do I'm not familiar with the .setDescription function method and typically use the following for double arguments:
args << fan_rise
fans.each do |fan|
# set common inputs
if fan_eff_tot > 0
end
if fan_rise > 0
end
