Good questions, There isn't a direct way to do either of these, so my numbered answers describes a work around. If you like you can document this enhancement request in the Issues Page of the GitHub Repository for FloorspaceJS.
It doesn't appear that there is a way to re-order the stories in FloorspaceJS interface to do this, however if you are comfortable editing a JSON file in a text editor you can re-order the
stories
object in the order you want, and then re-load in the GUI. Of course if you are going to try to edit this by hand you should edit a copy of the file so you have a clean one to revert back to. Here is a compressed view of the JSON, make sure that comes in adjusted file are valid JSON (no comma on last item)There isn't a way to alter the JSON file to support this like there is for your first question, however there are a number of measures that can help. For example there is a measure that will set exterior walls to ground boundary condition by story on BCL. I also have a measure I have not published yet but will soon, and can email you, that converts exterior walls by cardinal direction to adiabatic. It is based off of a measure on BCL that makes interior walls and floors adiabatic.
As a note to related to the below story grade, the FloorspaceJS object model and development interface does have a ground properties floor offset field that is part of what your second question is asking for. You won't see this in the current OpenStudio application, only the web development version. I have not confirmed this, but I expect that the merge to OSM does not yet support this, but it could in the future.
It doesn't appear that there is a way to re-order the stories in FloorspaceJS interface to do this, however if you are comfortable editing a JSON file in a text editor you can re-order thestories
object in the order you want, and then re-load in the GUI. Of course if you are going to try to edit this by hand you should edit a copy of the file so you have a clean one to revert backto. Here is a compressed view of the JSON, make sure that comes in adjusted file are valid JSON (no comma on last item)to.There isn't a way to alter the JSON file to support this like there is for your first question, however there are a number of measures that can help. For example there is a measure that will set exterior walls to ground boundary condition by story on BCL. I also have a measure I have not published yet but will soon, and can email you, that converts exterior walls by cardinal direction to adiabatic. It is based off of a measure on BCL that makes interior walls and floors adiabatic.
Good questions, There isn't a direct way to do either of these, so my numbered answers describes a work around. If you like you can would be good for you to document this enhancement request in the Issues Page of the GitHub Repository for FloorspaceJS.
- It doesn't appear that there is a way to re-order the stories in FloorspaceJS interface to do this, however if you are comfortable editing a JSON file in a text editor you can re-order the
stories
object in the order you want, and then re-load in the GUI. Of course if you are going to try to edit this by hand you should edit a copy of the file so you have a clean one to revert back to. - There isn't a way to alter the JSON file to support this like there is for your first question, however there are a number of measures that can help. For example there is a measure that will set exterior walls to ground boundary condition by story on BCL. I also have a measure I have not published yet but will soon, and can email you, that converts exterior walls by cardinal direction to adiabatic. It is based off of a measure on BCL that makes interior walls and floors adiabatic.
