You cannot translate an .idf with HVAC system and especially EMS code into OpenStudio model format (.osm). Only some simple constructions, materials, geometry, and loads can be imported.
If you want the 90.1-2016 DOE prototype in OpenStudio format, you will need to wait until 90.1-2016 is supported in openstudio-standards.
[EDIT: There are no funded efforts to add 90.1-2016 to openstudio-standards this year].
[EDIT TO THE EDIT: 90.1-2016 will be added to openstudio-standards in FY2021]
openstudio-standards. [EDIT: There are no funded efforts to add 90.1-2016 to openstudio-standards this year].
year]. [EDIT TO THE EDIT: 90.1-2016 will be added to openstudio-standards in FY2021]
If you want the 90.1-2016 DOE prototype in OpenStudio format, you will need to wait until 90.1-2016 is supported in openstudio-standards. [EDIT: There are no funded efforts to add 90.1-2016 to openstudio-standards this year].
[EDIT TO THE EDIT: 90.1-2016 will be added to openstudio-standards in FY2021]year].
If you want the 90.1-2016 DOE prototype in OpenStudio format, you will need to wait until 90.1-2016 is supported in openstudio-standards. [EDIT: There are no funded efforts to add 90.1-2016 to openstudio-standards this year].openstudio-standards, which should be done by September 2020.
