hey i am trying to do the exact same thing. i have given cooling setpoint as 24 and ventilation setpoint as 22 with outdoor temperature range 18-35. i am using AFN and have given ideal air load system(using template). so ventilation should work if the conditions are met else ideal air load system should b working. But it seems that ideal air load system is not getting shut..so sometimes i am getting ach and cooling load together for the zone. As you have done the same thing successfully can you help me rectify this problem?
