If you're using the OpenStudio application, you can go to the Simulation Settings tab, expand Simulation Control, and increase the "Maximum Number Of Warmup Days" above the default of 25.
If that doesn't help, there are also inputs for "Temperature Convergence Tolerance Value" and "Loads Convergence Tolerance Values" that could be changed as a fallback.
If that doesn't help, there are also inputs below for "Temperature Convergence Tolerance Value" and "Loads Convergence Tolerance Values" that could be changed as a fallback.
