I looked into this and discovered it's a bug that is specific to the Wood Stove upgrade. None of the other heating/cooling systems have this bug. Thanks for reporting the issue.
EDIT: The issue has been resolved. If you grab the latest code, it will work.
I looked into this and discovered it's a bug that is specific to the Wood Stove upgrade. None of the other heating/cooling systems have this bug. I've issued a partial bugfix here, but one other issue remains to be addressed by another team member before it will work. Once you see that the link above has been marked as "merged", you'll be able to grab the latest code and have it work. Thanks for reporting the issue.
