If you would like to manually control the air flow rate, I would suggest checking out the suggestions in the following three unmethours posts which uses EMS to manually adjust airflow. I think that's the only way to do what you want.
  1. Overriding fan mass air flow in EMS
  2. How to overwrite the terminal box airflow
  3. How to set VAV mass flow rates by EMS?
