@katmojo Did you rename or move your OSM file away from the associated files. If you OSM is named MyModel.osm
next to it should be a directory named MyModel
. Inside that should be a file named floorplan.json
. If this is the case, then rename the directory and the plan back to original name. You can also import the old floorplan.json
using the geometry editor sub-tab.
