@Adrien the measures, the arguments for the measures, and the weather file are not stored in the OSM file. There is a directory next to the OSM file with the same name that contains this information. Renaming or moving these, without all of the elements will result in the behavior you described. Below is an example screenshot. Note that if you used FloorspaceJS there would also be a floorplan.json file that contains the 2d floorplan.
For reference, the OpenStudio Application uses an OpenStudio Workflow (OSW) file which is also used by PAT for individual datapoints. It is the OSW file that contains the arguments for the measures. The command line interface for OSW's is documented here in case you want to learn more abut the files.
