@Phan Truong what operating system are you using? I was able to open the model and OpenStudio Results and run the simulation, save, quit, and re-open the model. I do see a crash when I go to the geometry tab to view 3d geometry, however it opens fine in the SketchUp Plugin. I'll look into the cause of this.
For reference, in inspecting the model in the SketchUp Plugin I noticed a few surfaces that should have been roofs that were floors instead. I believe they may have been roofs with reversed face normals that the plugin altered. Either way that should be addressed in your model. I also noticed you were using adiabatic boundary conditions for interior walls. It looks like you intended to do this for floor/ceilings as well, but while ceilings were made adiabatic, the floors of all spaces still have a ground boundary condition, which you should change.
For reference, here is view of the Results HTML.
I'll update this answer once I identify the cause of the crash on viewing of geometry in OS app.
