If you are simulating multiple years with different weather data each year, I don't think you can have different tariffs apply to different years using the Economic:Tariff objects in EnergyPlus. Instead you would have to simulate each year separately with different tariff associated with each year.
If your weather is going to be the same for each year, you could just define multiple tariffs in a single EnergyPlus file and simulate just the one year. You would then get all the results for the different tariffs in the Economics Results Summary Report report.
