Hi, you should not save the model using the SketchUp tools but the Euclid's ones. For example: when working on your model click on "Extension-->Euclid-->Save". Then, closing the model, don't save the SketcUp file. When opening again you model follow this procedure: Open SketchUp app, click on "Extension-->Euclid-->Open" and then select your idf file.
